hi folks, i am using M58BW016FB flash memory as boot memory for MPC8358E processor in that i struct at writing a data into the memory . i am using freescale code warrior soft. for writing data into memory..
Vd.1
can you please help me how to write data into this flash and what are the commands and steps i have to follow....
thank you.
regards,
venkat d
Pretty sure the Data Sheet specifies the commands the device supports, and it programs much like every other NOR FLASH memory from the last few decades.
Review JEDEC CFI implementation, and flow charts in data sheet.
i followed the command which is given in datasheet but the data not able to store on specified address.
can tell me the steps?
