Flashing STR711 with GNU Toolchain & JTAG-Wiggler
chrisstud9
Posted on June 10, 2005 at 16:00
chrisstud9
Posted on May 20, 2005 at 14:42
i want to programm the STR711 via a JTAG-Wiggler and GNU-Debugger/Insight. Is it possible to programm the internal flash directly using the Toolchain from GNUARM? Or do i need to programm the flash by executing a ''flashing application'' from the internal RAM?
If so, is there any (free!) code for doing this offered by ST? Or a free flashing-tool?
Thank you !
Chris
md1
Posted on May 26, 2005 at 07:29
If you download our free toolchain www.st-angliamicro.com/software.asp we provide a flasher utility for the Wiggler.
Best Regards,
Martin Davey.
[ This message was edited by: MD on 26-05-2005 10:59 ]
chrisstud9
thank you very much :)
im using your idealist software right now ....
