EXTINT5 -32 Interrupts
cdixon
Posted on March 10, 2008 at 01:19
cdixon
Posted on May 17, 2011 at 09:48
Just a beginner so sorry if this is very basic question (I can't seem to find the required docs anywhere ;
How do I enable EXTINT 5 using ST Libraries ? (Using the MCB-STR9 Eval Board and I would like to use the Push Buttons, s3 and s2 (EXINT5 and EXINT6)
hicham
Hi cdixon,
Try the following post if you still haven't been able to solve your problem.
http://www.st.com/mcu/forums-cat-6516-21.html
Beware that you can only use one of the two buttons SCU WKUPSEL register does not allow you to select more than one. For documentation, check out
http://www.st.com/mcu/devicedocs-STR912FW44-101.html
. The first three pdfs are your most valuable information source.
However, I am also facing some side effects problems, but you can get a starting idea of how to make use of your push buttons.
