External SRAM troubles
bhines
Posted on July 06, 2007 at 14:55
bhines
Posted on May 17, 2011 at 11:31
I have a 512k by 8 bit SRAM interfaced to an STR912FW44 via 8-bit multiplexed mode using CS0. Whenever I write a byte to it, it writes the same byte into 4 locations in the SRAM two bytes 10 hex apart in two places 100 hex apart. What am I doing wrong? The compiler is keil C.
