!!!! Ethernet Minimodule with ARM9 STR912 Microcontroller !!!!
okulicz
Posted on May 03, 2008 at 08:42
okulicz
Posted on May 17, 2011 at 09:50
Quote:
On 08-03-2008 at 21:53, Anonymous wrote:
MMstr912 minimodule
* Complete, ready to use system based on ARM9 STR912 microcontroller
* STR912 - ARM966E RISC core, up to 96MHz with Ethernet controller
* Ethernet PHY STE100P
* Onboard 8MB serial Flash memory
* 61 I/O pins
* Onboard 25MHz crystal
* Onboard 32kHz for RTC
* Onboard 1.8V voltage regulator for core
* Requires single power supply 3.3V
* LED diodes for status indication
* 2 x 40 terminals with 0.1'' (2.54 mm) pith, fitting every prototype board
* Place for battery socket for RTC and RAM backup
* Small dimensions: 36mm x 56mm
* Available evaluation board and sample software
http://www.propox.com/products/t_163.html?lang=en
:o :o :o :o
okulicz
MMstr912 minimodule
* 61 I/O pins
:o :o :o :o
[ This message was edited by: okulicz.andrzej on 03-05-2008 12:13 ]
