2004-04-24 1:16 AM
2011-05-17 3:00 AM
I try to disable the DDC SRAM on uPSD3234 by follwing code in STARTU32.A51 DDCCON DATA 0D7H S1CON DATA 0D8H : MOV A, 0 ; Disable DDC and DDC XRAM out of addr space MOV DDCCON, A MOV S1CON, A ; Disable DDC I2C as well : But it seem that the DDC SRAM still conflict with our FLASH chip with address 0x00ff~0xffff. Can you give me any ideal about that? Thank for your help. With Regards. Healy2011-05-17 3:00 AM
The asm is incorrect, it should be mov A, #0
Regards sjo
