comunication with Master & Slave on ST7 and ST6
ibb
Posted on September 03, 2004 at 05:53
ibb
Posted on June 13, 2004 at 13:04
Hi; on any helps
I search an assembler or ST-Realizer2 application for a ST6265 master
and a ST72331N4 as a slave, I have load same sample (without) an
emulator, but there is no signal.
Have any body thes realize in actual projekt.
The world wait for these application.
Best Regards
[ This message was edited by: Goliath on 14-06-2004 00:34 ]
rene2
Does your problem still exist?
As a new member on this forum, it's a bit late perhaps but I'd like to point out that you perhaps did not initialize the Slave Select pin on the device.
I know that Actum Solutions provides an application note and Realizer examples with their product. Check on www.actum.com.
Balvie
