Clock Select STR71x
sven239955
Posted on September 29, 2006 at 11:21
Clock Select STR71x
sven239955
Posted on September 29, 2006 at 10:47
1. Before we enter the LPWFI mode we externally stop the CK clock (2MHz).
(Which is selected and used with PLL (->24MHz)).
2. After stopping the clock we enter the LPWFI mode (RCCU->SMR &= 0xFE).
Which clock is used after the CK clock is not running more
and the cpu Enter LPWFI mode?
alain2399
This is the ST7 forum and not the ARM7 one. Repost your question in the appropriate forum if you want an answer.
