clock for usb
dante
Posted on April 27, 2006 at 08:52
clock for usb
dante
Posted on April 20, 2006 at 09:28
we expect to use a STR710F in a USB device.
For this reason we should use a 16MHz external clock generator (multiplied by factor 3 to reach the 48MHz USB sampling clock).
My question is: is possible to run the ARM core at higher speed than 48MHz e.g. 64MHz in a device having a singel 16MHz clock source?
thanks
dante
Posted on April 27, 2006 at 04:57
Hi RISC,
thanks for your answer, but I am still little confused. The approach is to feed the same external clock source to both PLL1 and 2 inputs ?
dante
thanks.
