CAN PROBLEMS
Options
‎2008-10-07 11:08 PM
4 REPLIES 4
Options
‎2011-05-17 12:56 AM
Posted on May 17, 2011 at 09:56
I have a microntoller (PIC) sending every 100mS a 8 bytes long message.
On STR912 side, I have defined a msgobject to receive this message. The message I receive is sometimes (1 on 1000) corrupted. It is always the same byte has the same incorrect bit. Bitrate is on both sides 500K and is correct. I changed bitrate to 100KB with no result. I am sure that the message on the CANbus itself is correct. I capture the CAN message with a PC with CAN card. To receive message I use the CAN_Receivemessage() function of the ST-library (no interrupt is used). Any idea what I could try ? Is it necessary to call CAN_Releaseobject each time I call CAN_Receivemessage() ? LucOptions
I decreased the PCLK to 48MHz. Problem seems to be solved...
Another item in the errata list ?Options
Check out the datasheet. It clearly states the maximum frequency of PCLK is 48MHz in the electrical specifications section.
I know there's missing parts and ambiguities, but you should familiarise yourself with what is there.Options
shame on me !
