CAN bitrate values
craig239955_st
Posted on April 17, 2007 at 11:54
CAN bitrate values
craig239955_st
Posted on May 17, 2011 at 09:41
Hi all,
When using the CAN_library, the APB_CLK is supposed to be 8MHz.
I use 48MHz. Is it sufficient to multiply all the Bitrate prescaler values (BRP) in the CanTimings struct by 6?
Microchip has a utility (Visual initializer)to calc the values that have to be entered into the registers to get the correct CANbitrate (In fact this utility can be used to initialize all the pheripherals on a PIC) . Does this exists for STR9 ?
Kind regards,
Luc.
craig239955_st
Thank you ...
Luc
