Uart driver code for str912fw44
girija_79
Posted on November 23, 2006 at 02:37
girija_79
Posted on May 17, 2011 at 11:31
Hi everybody!
i am writing driver code for uart(of str912fw44) i am very new to this processor i was working with LPC21xx from past 2 weeks i am into this st and i have my deadline nearing please help me by telling what is wrong in my code and i havenot found datasheet for str912fw44 can anyone help me with that and help with my driver code
void main()
uint8_t a[5];
UART_InitTypeDef UART_InitStructure;
void SCU_Configuration(void);
void GPIO_Configuration(void);
#ifdef DEBUG
debug();
#endif
/* Configure the system clocks */
SCU_Configuration();
/* Configure the GPIO ports */
GPIO_Configuration();
UART_InitStructure.UART_WordLength = UART_WordLength_7D;
UART_InitStructure.UART_StopBits = UART_StopBits_2;
UART_InitStructure.UART_Parity = UART_Parity_No ;
UART_InitStructure.UART_BaudRate = 9600;
UART_InitStructure.UART_HardwareFlowControl = UART_HardwareFlowControl_RTS_CTS;
UART_InitStructure.UART_Mode = UART_Mode_Tx_Rx;
UART_InitStructure.UART_FIFO = UART_FIFO_Enable;
UART_InitStructure.UART_TxFIFOLevel = UART_FIFOLevel_1_2; /* FIFO size 16 bytes, FIFO level 8 bytes */
UART_InitStructure.UART_RxFIFOLevel = UART_FIFOLevel_1_2; /* FIFO size 16 bytes, FIFO level 8 bytes */
UART_DeInit(UART0);
UART_Init(UART0, &UART_InitStructure);
/* Enable the UART0 */
UART_Cmd(UART0, ENABLE);
UART_ReceiveData(UART0, &a[0] );
UART_SendData(UART0, a[0]);
/* Enable the UART0 Clock */
SCU_APBPeriphClockConfig(__UART0, ENABLE);
/* Enable the GPIO2 Clock */
SCU_APBPeriphClockConfig(__GPIO2, ENABLE);
/* Enable the GPIO3 Clock */
SCU_APBPeriphClockConfig(__GPIO3, ENABLE);
/* Enable the GPIO5 Clock */
SCU_APBPeriphClockConfig(__GPIO5, ENABLE);
/*Configure UART0_CTS P2.0*/
GPIO_DeInit(GPIO2);
/*After DeInit function P2.0 = UART0_CTS (defaut configuration)*/
GPIO_DeInit(GPIO5);
/*Gonfigure UART0_Rx pin GPIO5.1*/
GPIO_InitStructure.GPIO_Direction = GPIO_PinInput;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ;
GPIO_InitStructure.GPIO_IPConnected = GPIO_IPConnected_Enable;
GPIO_InitStructure.GPIO_Alternate = GPIO_InputAlt1 ;
GPIO_Init (GPIO5, &GPIO_InitStructure);
GPIO_DeInit(GPIO3);
/*Gonfigure UART0_Tx pin GPIO3.4*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt3 ;
GPIO_Init (GPIO3, &GPIO_InitStructure);
/*Gonfigure UART0_RTS pin GPIO3.3*/
GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
void UART_SendData(UART_TypeDef* UARTx, uint8_t Data)
//while ((UARTx->FR & 0x0060)==0);
// UARTx->FR |= UART_Enable_Mask;
/* Transmit one byte */
UARTx->DR = Data;
* Function Name : UART_ReceiveData
* Description : Returns the most recent received Byte by the UARTx peripheral.
* Input : UARTx: where x can be 0,1 or 2 to select the UART peripheral.
* Output : None
* Return : The received data
uint8_t UART_ReceiveData(UART_TypeDef* UARTx,uint8_t *pdata )
//while(!(UARTx->DR & 0x00ff)==0);
/* Receive one byte */
*pdata = UARTx->DR;
// return ((uint8_t)UARTx->DR);
return 0;
please see whether my send data and receive data modules are correct
Thanking all of u all in advance please do help me since i am very new to this microcontroller and this field tooo ,
