fboudra
stpc elite ide
  • February 17, 2004
  • 3 replies
  • 996 views
Posted on February 17, 2004 at 13:17
stpc elite ide
fboudra
fboudraAuthor
Posted on February 10, 2004 at 11:00
i try to use the loader from the stpckit. With the evaluation board, it works fine.
But with my card, it hang in HWIDE_GetHardDiskInfo :
BEGIN : HWIDE_GetHardDiskInfo
ulDevice = 0x1 (1)
pucInfo = 0x56180
BRANCH : Secondary IDE
BRAnCH : Master drive
LOOP : Wait not busy
On the evaluation board, i use an ide harddisk in secondary master (like the sample).
On my card, we got an ide flashdisk and only one connector for the flashdisk so it's in primary master.
the ReadBlockSector256Max and the conversion from LBA to CHS doesn't work :
BEGIN : HWID_ReadBlockSector256Max
ulDeviceID = 0x20020003 (537001987)
ulLBA = 0x0 (0)
pucBuffer = 0x563e0
ulCount = 0x1 (1)
BRANCH : Primary IDE
BRANCH : Master drive
INFO : Convert LBA to CHS
usCylinder = 0x0
ucHead = 0x0
ucSector = 0x1 (1)
An other thing, i don't understand, my card doesn't hang always in the same function.
How can i easily change the loader for only use the primary ide ? ( i don't have the secondary ide on my card )
What's the problem with the LBA and CHS ?
i join a capture of what i have if someone have got an idea.
thks
fboudra
fboudraAuthor
Posted on February 10, 2004 at 12:19
the attachment doesn't work :
Init Mem Shd Opt Pci Cpy Ldr
BEGIN : OSAL_Init
BEGIN : SWALLOC_NewHeap
psHeap = 0x66d4
pucBegin = 0x66fc
ulSize = 0x40000 (262144)
END : SWALLOC_NewHeap
BEGIN : HWTIMER_InitWaitFunction
BEGIN : HWTIMER_SetMode
ulTimer = 0x2 (2)
ucMode = 0x0 (0)
END : HWTIMER_SetMode
END : HWTIMER_InitWaitFunction
END : OSAL_Init
BEGIN : REGHOST_Init
ulLib = 0xffff (65535)
END : REGHOST_Init
BEGIN : DBGLOG_OpenSerial
Enable IDE controller...
BEGIN : HWPCI_ScanBus
BRANCH : Scan the bus for the first time
LOOP : Scan the 32 devices
BRANCH : Valid device found
BRANCH : Multiple functions device
LOOP : Scan the 7 other functions
BRANCH : Valid function found
LOOP : Send the function for each device
BEGIN : HWPCI_SetIDEInLegacyMode
ulDevice = 0x5800 (2252
ulParam = 0x0 (0)
END : HWPCI_SetIDEInLegacyMode
ulReturn = 0x1 (1)
ulDevice = 0x6000 (24576)
ulParam = 0x0 (0)
ulReturn = 0x1 (1)
ulDevice = 0x6100 (24832)
ulParam = 0x0 (0)
BRANCH : Found IDE class code
BRANCH : This IDE device can be set in legacy mode
ulReturn = 0x0 (0)
END : HWPCI_ScanBus
Look for kernel partition...
BEGIN : HWIDE_FindPartition
ulType = 0x21 (33)
pulDeviceID = 0x0
pulLBA = 0x0
pulSize = 0x0
BEGIN : HWIDE_LoadPartitionTable
LOOP : IDE device scan
BEGIN : HWIDE_GetDeviceID
ulDevice = 0x3 (3)
BRANCH : Use a temporary buffer for identify command
BRANCH : Start identify command
ulDevice = 0x3 (3)
pucInfo = 0x56180
LOOP : Wait no more busy
BRANCH : No error
BRANCH : Data received
LOOP : Copy sector to buffer
END : HWIDE_GetHardDiskInfo
ulError = 0x0 (0)
BRANCH : Device found
END : HWIDE_GetDeviceID
ulID = 0x20020003 (537001987)
BRANCH : Valid IDE device
BEGIN : HWIDE_ReadBlockSectors
ulLBA = 0x0 (0)
pucBuffer = 0x563e0
ulCount = 0x1 (1)
LOOP : 256 sectors read loop
BRANCH : Last 256 packet
BEGIN : HWIDE_ReadBlockSectors256Max
ulLBA = 0x0 (0)
pucBuffer = 0x563e0
ulCount = 0x1 (1)
usCylinder = 0x0 (0)
ucHead = 0x0 (0)
ucSector = 0x1 (1)
LOOP : Copy sectors
END : HWIDE_ReadBlockSectors256Max
ulError = 0x0 (0)
ulError = 0x0 (0)
BRANCH : Valid partition sector
LOOP : Scan the partition table
END : HWIDE_PartitionInfo
ulError = 0x0 (0)
ulDevice = 0x2 (2)
ulDevice = 0x2 (2)
pucInfo = 0x56180
BRANCH : Slave drive
BRANCH : No error
BRANCH : No data received
ulError = 0xfffffffd (4294967293)
BRANCH : No device found
ulID = 0xffffffff (4294967295)
BRANCH : No valid IDE device
ulDevice = 0x1 (1)
ulDevice = 0x1 (1)
pucInfo = 0x56180
WARNING : Data waiting to be process
ulError = 0xfffffffe (4294967294)
ulDevice = 0x0 (0)
ulDevice = 0x0 (0)
pucInfo = 0x56180
fboudra
fboudraAuthor
hi,
the stpckit/bootloader doesn't work with IDE flashdisk from M-Systems.
if no one can help on this forum/st support site, where can i find help ??
if someone successfully used linuxbios/freebios, i'm also interested.
best regards
