2003-12-02 04:19 AM
2003-12-02 04:19 AM
I'm using Atlas in Local Bus mode on a CPU board and the only way to toggle a NMI via external signal seems to be PCI #SERR signal, after enabling this feature via north&southbridge configuration and port 70H enable (clearing bit 7). Is this correct? It seems Atlas does not receive a NMI when I drive low #SERR signal: why? Is there a way to toggle NMI via a HW signal? Thank you in advance, Fabware.
