julien239955_stm1_st
st72F521 checksum problem
  • June 14, 2007
  • 803 views
Posted on June 14, 2007 at 07:36
Posted on June 12, 2007 at 12:31
I'm in front of a problem by the using of a function which should give the checksum of my software.
#ifdef USE_HDFLASH_CHECKSUM
ROUTINE NAME : HDFlashChecksum
INPUT : Flash address, Frequency
OUTPUT : Embedded Command Status
Returned values of Checksum are in EMBLG_PARAM_ENDH and
EMBLG_PARAM_ENDL addresses
DESCRIPTION : Compute a Checksum
unsigned char HDFlashChecksum(unsigned char *Flash, unsigned char Freq)
EMBLG_PARAM_ECMD = 0x06;
EMBLG_PARAM_PTRL = ((int)Flash & 0xFF); // Flash Address Low Byte
EMBLG_PARAM_PTRH = ((int)Flash >> 8); // Flash Address High Byte
EMBLG_PARAM_FREQ = Freq;
FCSR = 0x00; // Launch command (no need to wait end of operation)
return EMBLG_PARAM_ECMD; // Return Embedded Command Status
#endif
How can I know the ''Flash Address Low Byte'' of my soft? So what should be the value of ''Flash''?
thanks for your help
wolfgang2399
although I don't really comprehend your problem in detail, I'll try to give some ideas.
Declaring the EMBLG_PARAM_PTR as pointer to an unsigned character with
char *EMBLG_PARAM_PTR;
you'll get the two byte number EMBLG_PARAM_PTR as pointer to an unsigned char.
To calculate the checksum you only have to add all the values of your flash from the first to the last byte.
checksum = 0;
for(EMBLG_PARAM_PTR = FLASH_FIRST_BYTE; EMBLG_PARAM_PTR <= FLASH_LAST_BYTE;) checksum += *(EMBLG_PARAM_PTR++);
where FLASH_FIRST_BYTE and FLASH_LAST_BYTE are constant pointers to the first and to the last byte of your flash.
But pay attention: If FLASH_LAST_BYTE == 0xFFFF you'll meet a serious problem: Increasing EMBLG_PARAM_PTR (== 0xFFFF) causes an overrun to 0x0000. Then the query EMBLG_PARAM_PTR <= FLASH_LAST_BYTE will give a wrong result and you might enter a deadloop!!!
In this case better use
checksum = 0;
for(EMBLG_PARAM_PTR = FLASH_LAST_BYTE; EMBLG_PARAM_PTR >= FLASH_FIRST_BYTE;) checksum += *(EMBLG_PARAM_PTR--);
Alternatively to declared constants you might take numerical constants as addresses:
checksum = 0;
for(EMBLG_PARAM_PTR = (unsigned char*)0xFFFF; EMBLG_PARAM_PTR >= (unsigned char*)0x8000;) checksum += *(EMBLG_PARAM_PTR--);
Hope it will help you to find a solution,
WoRo
