st7 lite0 AD problem
huaer2000
Posted on September 30, 2004 at 03:00
huaer2000
Posted on September 20, 2004 at 03:34
I want to use lite0x MCU A/D converter with amp enable. Can I input the
signal larger than 250mv?
BR,
mcuinterest
alok2
The Amp works in linear mode upto 250mV as mentioned in specs. Above that, you many use but only on your risk, the result may not be linear.
