I failure read EPROM from st62T65B6
1adc
Posted on May 11, 2004 at 13:54
1adc
Posted on May 11, 2004 at 10:18
Hello!
My ST62T65B6 is controled PLL FM exciter.
What for winee.exe send message ''device is protect'' when try read?
I not another programd ST62T65 and much read program from EPROM
How read EPROM and program ?
Thank!
joern2
In case the Programmer works properly and the device is neither defective nor disconnected check the protection bit.
Find the following text in the specification:
1.3.2.1 Program Memory Protection
The Program Memory in OTP or EPROM devices
can be protected against external readout of memory
by selecting the READOUT PROTECTION option
in the option byte.
In the EPROM parts, READOUT PROTECTION
option can be disactivated only by U.V. erasure
that also results into the whole EPROM context
erasure.
Note: Once the Readout Protection is activated, it
is no longer possible, even for SGS-THOMSON,
to gain access to the OTP contents. Returned
parts with a protection set can therefore not be accepted.
PROTECT. This bit allows the protection of the
software contents against piracy. When the bit
PROTECT is set high, readout of the OTP contents
is prevented by hardware. No programming
equipment is able to gain access to the user program.
When this bit is low, the user program can
be read.
