Hi I'm using the STR911in project with Keil and ULink2 debugger. I can not set a breakpoint in C code but I can set assembly. I load my code in a microcontroller however I can not view memory map and variable.
masnmz
This is debug setting in my project.
http://www.keil.com/support/docs/3902.htm
Although I'm doing this instruction but not working.
0 REPLIES 0
