2008-02-24 08:21 PM
2008-02-22 01:49 AM
Hello all,
I am using the ST7FOXU0 and now I’m not able to found its datasheet on the web. The only file I found is the ST7FOXA0 datasheet. I had a brief look to it and it seems that only the named has changed. May I have missed something? Is someone could confirm me this name changing? Thanks and regards, Joao2008-02-24 08:21 PM
Hello Joao
You’re right; it’s only a name changing. The ST7FOXU0 is renamed in ST7FOXA0. Even if the name change there is exactly the same thing inside 😉 ST7FOXA0 = ST7FOXU0 Regards Cheng [ This message was edited by: cheng.wu41 on 25-02-2008 09:52 ]
