SPC560B50x CAN Transmit Interrupt not working
Mayank Bhatt
Posted on July 20, 2017 at 17:35
Hi
I am working on SPC560B50x controller and trying to send CAN messages from the controller to the busmaster tool.
I am unable to hit CAN transmit ISR breakpoint, but messages transmitted  through my controller is getting reflected in the busmaster tool.
CAN configuration is as follows-:
1) Using CAN channel 0.
2) Baudrate 500 kbps.
3) No FIFO being used.
4)  Lowest Buffer transmitted first
5) Max Message Buffers used are 32 for all IMASK1 is enabled ( value given = 0xFFFFFFFF).
6)  Bus Off, Error, Tx Warning, Rx Warning all are enabled.
7) All being done in the freeze mode.
In CAN_Transmit function I am setting appropriate code for transmission.
I am using 32 message buff to transmit 32 different data, same message ID over CAN bus and clearing all IFLAG1 after transmission.
Code snippet is attached.
Please help so that I may be able to hit the
CAN transmit ISR breakpoint and I may proceed further.
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
2 REPLIES 2
Mayank Bhatt
Posted on July 21, 2017 at 07:29
Please help
Erwan YVIN
Posted on August 09, 2017 at 16:49
Hello ,
it should be the same answer as :
https://community.st.com/0D50X00009XkXW2SAN
Best regards
Erwan
