missing-QuestionPost
SPC560B50x CAN Transmit Interrupt not working
Posted on July 20, 2017 at 17:35HiI am working on SPC560B50x controller and trying to send CAN messages from the controller to the busmaster tool.I am unable to hit CAN transmit ISR breakpoint, but messages transmitted  through my controller is gett...
Resolved! CMU - FMPLL clock reference values
Posted on July 19, 2017 at 10:02Hello everyone,I'm working with SPC56EL60L3 and SPC5Studio v5.0.I'm not sure I get how does the CMU_0 FMPLL clock monitoring work.Reading the user manual (RM0032) at page 277 13.3.3 and 13.3.4, I've found some details...
Resolved! Startup kit for making Car's ECU
Posted on July 25, 2017 at 10:28Hi, I'm new with STM and I feel lost  about where to start with it.As my subject, I would like to make my own Car's ECU.First I would like to select the startup board.I think I will choose SPC56M-DiscoveryIf there's a...
Resolved! System Clock Frequency SPC58
Posted on June 27, 2017 at 14:18Hi,Just started working at a new place and we are using a STC58NE84xx. It's a new part for me, I've never used a micro-controller as complex as this. Very simple: I'm trying to verify the system clock frequency. I thi...
Flexray to Optical fiber communication??
Posted on June 23, 2017 at 07:21Hello All,Currently, We are developing a product based up on Safe Microcontroller for safety critical application.We want to convert the Flexray communication to Optical Fiber single mode communication for longer dist...
Resolved! Problem in Clock output Generation
Posted on June 20, 2017 at 13:43Hello All,I am working on SPC560B54L5 board using SPC5studio version 5.2.3.I am trying to generate the clock output using the XOSC frequency. I  enabled the corresponding GPIO (PA[0] for CLKOUT) by selecting the appro...
LIN SYNCH error
Posted on March 06, 2017 at 11:19Hi, Dear supportI face an issue with Sphaero LIN on spc574s60. We are in slave mode, using LINFLEX_0.Look the INESR value, in this state I can have LIN error interrupt, synch error and frame error. The team investiga...
Debugging checkstop reset on SPC560P44
Posted on June 14, 2017 at 11:52Hello,Under certain circumstances involving high interrupt load the CPU triggers a checkstop reset, RGM_FES is 0x8008 in after reboot, indicating the F_CHECKSTOP bit is set.How do I debug the source of the checkstop r...
