missing-QuestionPost
Resolved! Timer initialization prompts build error SPC560 test program
I have built LED blinky test program in SPC560B-DIS eval, I am setting and clearing LEDs in eval bord. I have introduced delay "osalThreadDelayMilliseconds(500);" between set and clear.I have used below code for my application, but it throws build er...
AK V by Associate II
  • 1028 Views
Resolved! Flexray 2 Node Communication Using Spc560p Microcontroller.
Hallo!!Can anyone give a solution for my problem.I am trying to develop flexray bus communication for two nodes. Using only the spc650p microcontroller not the development board and instead of development board, i am using a raisonance reva motherbo...
Gani by Associate
  • 809 Views
  • 1 replies
Resolved! SPC560B Flash driver
Hello,I use SPC560B50L3 with SPC5Studio.I have just realized I need flash library for bootloader.There is Flash Driver in SPC5studio market place but link is broken.So I asked for an SPC56xMBP-FLASH license key to <apgtools-license@st.com> but no ans...
Resolved! Why is BMP as a debugger alternative a banned keyword?
Hello,for explaining debugger alternatives, I wanted to give BMP as an example. However explaining it with full words triggers some filter and rejects the posting. BMP is a legal product https://1bitsquared.com/collections/supporting-hardware/ with s...
Resolved! How set a PWM using E_timer with a SPC570xx board?
Good morning,I'm trying to implement a simple PWM in a SPC5700 board usign an e timer. I'we follow all the suggestion in the datasheet and the compiler don't give any error but in debug mode my code doesn't work. So i wanna ask if i'm making some mi...
TGecc by Associate
  • 526 Views
  • 1 replies
Chip markings on the STSPIN32F0A
I recently purchased these from element14: https://in.element14.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&langId=91&urlRequestType=Base&partNumber=2797963&storeId=10186.The ones I got show this as the chip marking: https://i.imgur....
