2021-06-03 1:23 AM
2021-06-08 8:17 AM
Hi @Community member ,
the noise density at 6g is typically a little higher than the one at 2g.
as per my experience I'd say it is 20% higher.
if you need an exact value you can try to calculate and characterize your sensor.
hope this helps
Niccolò
p.s. if you found a solution to your problem, please, select a best answer to help other users with similar issues
2021-06-08 8:17 AM
hope this helps
Niccolò
2021-06-09 3:34 AM
Hi Niccolo,
Thank a lot for your answer. It was very helpful!
Best Regards
Jesper
