what is the difference between STEVAL-IDP005V2 vs STEVAL-IDP005V1
GVall.2
hallo everyone,
i would like to kno what is the difference between io link sensor  STEVAL-IDP005V2 vs STEVAL-IDP005V1. i could see version2 has a io link stack but no version1. is it possible to add io link stack to version 1?.
Thank you
Peter BENSCH
The STEVAL-IDP005V1 was part of the STEVAL-BFA001V1B, but it is NRND (Not Recommended for New Designs).
Yes, an IO-Link stack can be added, please get in contact with TE-Concept.
Good luck!
/Peter
GVall.2
Thank you for the answer. so can i use software package STSW-BFA001V2 for STEVAL-IDP005V1 instead of STSW-BFA001V1 fur STEVAL-IDP005V1
Can you please explain what is does it really means NRND. what are the limititation?.
Thanking you.
It means they won't support new designs with new customers for this part, and the longevity of the part is questionable.
Either it has been replacement by a newer part, or the line has been deemed unsupportable going forward.
Your local sales/support contacts might be able to provide specific reasons and decision drivers related to the movement to DRND
