We are using accelerometer ISM330DLC to find the Motor Frequency, Instead of 800Hz we are getting peak at 2KHz
SAlug.1
We are Reading Accelerometer Raw Data from the sensor and plotting FFT on excel sheet
  1. The ODR was configured to 6660(6.66Khz)
  2. Each Time we are reading 256 points of X, Y , Z
  3. Plz find the attachment for more details
The Motor is running at 800Hz we are observing peak at 2KHz . Not sure why we are getting wrong FFT plot .
Can you help why I am getting wrong FFT Plot.
4 REPLIES 4
Javier1
Principal
Put your accelerometer close to your PC speaker/phone and play some tones (VOLUME UP) with this https://www.szynalski.com/tone-generator/
Is the FFT matching the PC generated tone?
Thats how i debugg accelerometer and FFTs
Available for consulting/freelancing , hit me up in https://github.com/javiBajoCero
SAlug.1
Still the problem repeat .
I am using the tone generator at 440 Hz instead of 440Hz observing peak at 800Hz .
  2. Each Time we are reading 1024 points of X, Y , Z
  4. Can you let us know the reason why we are not observe a right peak ?
can you plz help me out on the below comment
what happens if you reproduce a 220Hz? you observe peak at 400hz?
