2020-03-12 12:19 PM
Is there a way to use the VL53L1X sensor to be dust and water resistant? I watched the Calibration-Free Dirty Environment Cover Glass Solution video and does this protective glass layer also provide water resistance?
2020-04-08 10:50 AM
The protective glass layer does in fact provides water resistance.
You can build your own, or you can buy it. Both as a separate piece or already integrated with the sensor.
have a look at the app note AN5231. Search for it on the ST web site.
That should give you some good ideas.
