UNICO GUI ODR
2023-08-23 12:08 PM
There are some abbreviations next to ODR: HP, HA, LP1, LP2, LP3, and NM. I believe HP stands for high performance, LP stands for low performance, and NM stands for normal mode. Can you explain the differences between LP1, LP2, and LP3? Additionally, I'm curious about the meaning of HA.
Fehmi K.
2023-08-25 1:24 AM
Hi Fehmi @FKara.3 ,
the HA stands for High Accuracy
while the difference between the different low power modes depends on the sensor, there are some with different low power modes that uses different current consumptions with different ODRs, you can refer to the sensor datasheet for specific information about those =)
If this answers your question, please, mark this as "best answer", by clicking on the "accept as solution" to help the other users of the community
Niccolò
