2024-07-25 1:09 PM
I would like the ability to generate an interrupt be programmed into the embedded flash so that I can use STHS34PF80 without a microcontroller. Is this possible?
2024-07-26 12:34 AM
Hi @joe_electric ,
STHS34PF80 has no embedded flash. You need a microcontroller to configure it, and then you can keep the microcontroller in sleep mode while the sensor is working.
