How to extract program from ".ucf" configuration file generated by unico?
2022-10-13 4:36 AM
In my project i am using LSM6SOX sensor to generate the interrupt for every 10 degree incrementation on X axis. I found this link...
https://github.com/STMicroelectronics/STMems_Standard_C_drivers/blob/master/lsm6dsox_STdC/examples/lsm6dsox_fsm_raw.c it worked well! Similar way of "/Program: glance/"
static const uint8_t lsm6so_prg_glance[] = {
0xb2, 0x10, 0x24, 0x20, 0x17, 0x17, 0x66, 0x32,
0x66, 0x3c, 0x20, 0x20, 0x02, 0x02, 0x08, 0x08,
0x00, 0x04, 0x0c, 0x00, 0xc7, 0x66, 0x33, 0x73,
0x77, 0x64, 0x88, 0x75, 0x99, 0x66, 0x33, 0x53,
0x44, 0xf5, 0x22, 0x00,
I am try to generate .ucf.. using this link... https://github.com/STMicroelectronics/STMems_Finite_State_Machine/tree/master/configuration_examples/example_0_fsm
`const ucf_line_t Free_fall[] = {
{.address = 0x10, .data = 0x00,},
{.address = 0x11, .data = 0x00,},
{.address = 0x01, .data = 0x80,},
{.address = 0x04, .data = 0x00,},
{.address = 0x05, .data = 0x00,},
{.address = 0x5F, .data = 0x4B,},
{.address = 0x46, .data = 0x01,},
{.address = 0x47, .data = 0x00,},
{.address = 0x0A, .data = 0x00,},
{.address = 0x0B, .data = 0x01,},
{.address = 0x0C, .data = 0x00,},
{.address = 0x0E, .data = 0x00,},
{.address = 0x0F, .data = 0x00,},
{.address = 0x17, .data = 0x40,},
{.address = 0x02, .data = 0x11,},
{.address = 0x08, .data = 0x7A,},
{.address = 0x09, .data = 0x00,},
{.address = 0x09, .data = 0x01,},
{.address = 0x09, .data = 0x04,},
{.address = 0x02, .data = 0x41,},
{.address = 0x08, .data = 0x00,},
{.address = 0x09, .data = 0x61,},
{.address = 0x09, .data = 0x10,},
{.address = 0x09, .data = 0x1A,},
{.address = 0x09, .data = 0x0F,},
{.address = 0x09, .data = 0xCD,},
{.address = 0x09, .data = 0x34,},
{.address = 0x09, .data = 0xAB,},
{.address = 0x09, .data = 0xF5,},
{.address = 0x09, .data = 0x77,},
{.address = 0x09, .data = 0x99,},
{.address = 0x09, .data = 0x12,},
{.address = 0x09, .data = 0x66,},
{.address = 0x09, .data = 0x53,},
{.address = 0x09, .data = 0xC7,},
{.address = 0x09, .data = 0x50,},
{.address = 0x05, .data = 0x01,},
{.address = 0x17, .data = 0x00,},
{.address = 0x01, .data = 0x00,},
{.address = 0x5E, .data = 0x02,},
{.address = 0x10, .data = 0x20,},
{.address = 0x11, .data = 0x60,}
I am able to generate above file which is different from above /* Program: glance / why it is different and How to generate same way (/ Program: glance */ ) and don't get any ideal to generate interrupt at every 10 degree.. I am using STEVAL-MKI197V1
Deepak Aagri
