STEVAL WESU1 Wearable sensor logs data for a fraction of a second and then stops? I'm using the Unicleo interface to view the exported data. The device connects successfully and once started logs data for ~1 second and then stops.
JDill.2
Eleon BORLINI
Hi @JDill.2​ ,
sorry for my late reply.
Are you still facing this issue?
Did you try the STEVAL-WESU1 Android/iOS app?
-Eleon
JDill.2
No problem. Yes, I've been trying to connect via bluetooth with my smartphone (android) and that also has issues.
I'm using the ST BLE Sensor app, it can find my device via bluetooth however once it connects it immediately prompts me for a firmware update.
The only option I have is to select a file. I've tried many downloads from the ST website but nothing will work and initiate the firmware update.
I've downloaded a second app, ST BlueDFU which will update the firmware over the air OTA, and says it completes successfully however it has no bearing on making the ST BLE Sensor app function.
Let me know your thoughts, or if I'm doing something wrong.
Thanks,
Jonathan
Hi Jonathan @JDill.2​ ,
did you try also with the custom app, the ST_WESU one? at least for the first configuration / FW download.
-Eleon
