2020-07-10 09:26 AM
I wanted to try the STEVAL-IDP005V1 from STEVAL-BFA001V1B,
I followed the description given in UM2438
and nothing worked,
Finally I realized that the cable description is wrong (or may be I've got a bad cable),
the ground is on white, not on blue wire
2020-07-14 09:03 PM
your right.
White is GND. The document description is different than actual wiring.
Do you feel lot of heat generated around Accelerometer?
2020-07-15 11:14 PM
yes, I feel heat too, a little warm, but it is normal, I think it is coming from MCU on other side, BR
