SensorTile box pro sampling frequency
stiwa_acceleration
I created a new flow with the mobile app (Expert Mode) using the acceleration sensor and the RTC time.
I adjusted the sample frequency of the acceleration sensor to 960Hz and choosed writing to SD card for output.
I used a user defines output file name to verify if the new file is generated correct.
After starting the logging with the app I had a look on the SD card.
The file was generated properly and also the acceleration data was saved properly, but the sample frequency is always 50Hz (20ms). Anyway what sample frequency I set, the output data is always 50Hz.
What do I need to adapt that the correct sample frequency is used?
Thank you for help.
Christian
2 REPLIES 2
Federica Bossi
Hi @stiwa_acceleration ,
Thank you for pointing this out to us, we have replicated the behaviour. The team is working to release a new corrected version as soon as possible. I will let you know, thanks for your patience!
stiwa_acceleration
@Federica Bossi Thank you for your support!
