2020-05-15 5:42 AM
2020-05-15 7:55 AM
We would like to emphasize that correct collecting with right kind of sensor is first needed to run more sophisticated algorithms and possible AI on top this data. You can then use STM32Cube.AI in order to compare and use pre trained model from all the current main frameworks such as Keras, TensorFlow and more. Today you can also use FP-IND-PREDMNT1 in order to easily trigger alarm based on your data monitored. As a next step, in coming weeks we plan to give you a solution which will allow you to teach, build the more effcient model and trigger intelligent alarm. Keep posted following ST press releases.
check these news
https://newsroom.st.com/media-center/press-item.html/t4259.html
