Shuyu Ma
Question about Soldering of LIS2DH12
  • December 23, 2016
  • 993 views
Posted on December 23, 2016 at 04:42
I am a new user of ST’s LIS2DH12. I am confused about the sentence 'Leave “Pin 1 Indicator� unconnected during soldering'. It was in chapter 4.1 Soldering information in datasheet of LIS2DH12. What this sentence mean? And why does Pin1 need disconnect?
And how can I achieve Leaving
Pin 1 Indicator
    Posted on December 23, 2016 at 14:19
    I agree the datasheet is confusing, but don't worry. For your information some devices have 'pin 1 indicator' on the bottom close to pin 1. I could be small dot or triangle, which looks like very small pad. The sentence says you should not solder this indicator. The pin 1 of course needs to be connected.
    It seem it is not the case of LIS2DH12, beacuse pin one is indicated by cut corner.
    Posted on January 03, 2017 at 15:09
    You can check my short description what is
    https://community.st.com/0D50X00009bMM4ZSAW
