Problem with SD card interface on Inemo
Options
‎2011-08-16 5:32 AM
Posted on August 16, 2011 at 14:32
Im facing a problem with the Inemo SDcard api. Iam able to read and write multiple blocks and single blocks but Im not able to erase the card. When I issue a command for erase and then read the block I always get 0xffff. Has anyone faced a similar situation or knows the reason why this is happening? Thanks and Regards, Hansen.Dsouza #inemo
3 REPLIES 3
Options
‎2011-09-22 5:41 PM
Posted on September 23, 2011 at 02:41
Hi Dsouza Hansen
I have also run into some problems in my attempts to implement the firmware for the microSD card slot. I see also that you have had no replies on your inquirer, and several other people have also posted questions regarding the microSD card without any answers. So I'm a bit curious to know if you have been able to solve your problem and whether you would be willing to share some of your experience? I believe it would lead to some answers for you and benefit the community here.All the best,HafrunOptions
‎2011-10-03 1:38 AM
Posted on October 03, 2011 at 10:38
hi hafrun and Dsouza Hansen!
i want to write sensors output to sd card. can u plz guide how to start. thanksOptions
‎2011-11-09 4:31 AM
Posted on November 09, 2011 at 13:31
Hi Hunzai,
Did you manage to overcome the problem with the iNEMO SD card? If yes, I will be glad if you can write what need to fix in order to make the iNEMO SD card to work. TNX Kobi
