My sensor tile box not responding yet all
vkosuri
Hello All,
My new sensor tile box STB011147 not responding yet all even connected USB power source to it's not responding,
I checked the battery was connected, however when I pressed power button no LED are turning on. please let me know how to resolve this issue.
Federica Bossi
Hi @vkosuri ,
Open the board box and make sure that the battery connector is inserted correctly. Connect a cable to a low-Power USB port, do not use high-power ports.
If you have a sensortile.box check that the LEDs light up in sequence.
If you have a sensortile.box pro, check that the green and yellow power LEDs light up.
If doesn't work, try to change a usb cable or port used.
Let me know if you solve the problem!
