MotionEC MotionEC_manager_run() output quaternion and euler is always 0? STM32CB+LSM303DLHC
‎2024-10-29 6:25 PM
‎2024-10-30 9:09 AM
I haven't personally used or seen MotionEC header file, (been using MotionFX). But assuming they're implemented in a similar manner - double check the header file and see if there any "enable" functions that need to be called before you call any run/calculate() functions to get quarternion/euler values generated.
‎2024-10-30 9:09 AM
