Marking code
DNguy.8
Hi ST Team,
Can you share the Marking code specification for the product: LPS22DFTR ?
Thanks,
Danny.
Correct, the marking of the LPS22DF is:
  • F (stands for the LPS22DF and packaging options like LPS22DFTR)
  • YWW (in your case 104 = 2021, wk 4)
/Peter
11 REPLIES 11
TR is just tape-n-reel delivery
@Peter BENSCH​ @Gildas HENRIET​
The LPS22DF is marked with the letter F, which can also be found on the packaging bag.
/Peter
DNguy.8
Hi Tesla and Peter,
Good day,
Thank you so much.
We received the parts .The all top side marking are F/ 104.
we check the datasheet have no any information to clearly our confusion.
Can you share the doccument ? we need to add it to the System for incomming check and ISO Audit
Thanks.
Danny.
The lack of marking information in the data sheets has been a persistent source of questions.
On the Need-to-Fix list, it needs to be a lot higher than making the Web Site prettier.. Surprised there's not an ISO requirement/expectation on ST's end
The number might be a YWW date code, would check the packaging, and trace info.
DNguy.8
Hi Tesla,
Thank you,
Imean that I want to understand marking guide from ST. It need to be maked the methode to check incomming part at Unigen.
About your explain we understand that The marking is F-YWW. It's True?
Thanks.
Danny
/Peter
DNguy.8
Hi Peter,
Thank you so much.
Regard,
Danny,
Great!
If the problem is resolved, please mark this thread as answered by selecting Select as best under your preferred answer. This will help other users find that answer faster.
/Peter
Hi Peter,
It's marked the preferred answer.
Thanks,
Danny,
