2022-08-16 11:12 AM
Hi ST Team,
Can you share the Marking code specification for the product: LPS22DFTR ?
Thanks,
Danny.
2022-08-17 11:51 PM
Correct, the marking of the LPS22DF is:
/Peter
2022-08-16 3:26 PM
TR is just tape-n-reel delivery
@Peter BENSCH @Gildas HENRIET
2022-08-17 12:56 AM
The LPS22DF is marked with the letter F, which can also be found on the packaging bag.
/Peter
2022-08-17 11:24 AM
Hi Tesla and Peter,
Good day,
Thank you so much.
We received the parts .The all top side marking are F/ 104.
we check the datasheet have no any information to clearly our confusion.
Can you share the doccument ? we need to add it to the System for incomming check and ISO Audit
Thanks.
Danny.
2022-08-17 12:39 PM
The lack of marking information in the data sheets has been a persistent source of questions.
On the Need-to-Fix list, it needs to be a lot higher than making the Web Site prettier.. Surprised there's not an ISO requirement/expectation on ST's end
The number might be a YWW date code, would check the packaging, and trace info.
2022-08-17 2:49 PM
Hi Tesla,
Thank you,
Imean that I want to understand marking guide from ST. It need to be maked the methode to check incomming part at Unigen.
About your explain we understand that The marking is F-YWW. It's True?
Thanks.
Danny
2022-08-17 11:51 PM
/Peter
2022-08-18 6:50 AM
Hi Peter,
Thank you so much.
Regard,
Danny,
2022-08-18 6:59 AM
Great!
If the problem is resolved, please mark this thread as answered by selecting Select as best under your preferred answer. This will help other users find that answer faster.
/Peter
2022-08-18 8:13 AM
Hi Peter,
It's marked the preferred answer.
Thanks,
Danny,
