2025-08-27 6:54 AM
My question is in regard with SLEEP_DUR of the register WAKE_UP_DUR.
Datasheet "LSM6DSV16X" (p98) mentions:
Duration to go in sleep mode. Default value: 0000 (this corresponds to 16 ODR) 1 LSB = 512/ODR_XL time"
Whereas the "AN5763" (p60) instead specify:
SLEEP_DUR_[3:0] bits of the WAKE_UP_DUR register: 1 LSB corresponds to 514 / ODR_XL time, where ODR_XL is the accelerometer output data rate. If the SLEEP_DUR_[3:0] bits are set to 0000, the duration of the inactivity state to be recognized is equal to 18 / ODR_XL time.
Not that the very similar specs impact product design itself, however I would prefer to know the correct one.
Thank you,
2025-08-29 1:54 AM
Hi @kierantraak ,
The application note is correct; we will modify the datasheet in the next release.
Thanks for notice us!
2025-08-28 6:11 AM
Hi @kierantraak ,
Thanks for letting me know, I'll check it out and get back to you!
2025-08-29 1:54 AM
Hi @kierantraak ,
2025-08-29 3:21 AM
Thank you very much for the precision.
