LIS2DH12TR Dimension Discrepancy
LWU.31
We received LIS2DH12TR bought from distributor source with full label and full lot code.
Our QC team checked with measuring equipment, and we found the height is above the max 1.0mm.
Is it considered normal phenomenon?
Referring to photo attached, thank you!
trick10
I encountered the same case here with the same part number, where the height is exceeding the 1.00Max tolerance.
Did you find any useful answers or documentation about this?
