2025-09-07 9:48 PM
Title: LSM6DSL FIFO data misalignment (XYZ rotated) and FIFO_PATTERN always 0 — how to align reads?
Body:
I’m using an LSM6DSL over I²C with an STM32. Goal: batch accelerometer-only samples into FIFO and drain clean (x,y,z) triplets at a fixed watermark. I keep running into two issues:
x,y,z 5, 250, 16870, 17, 258, 16825, -66, 221, 16828, -53, 284, 16834, Sampling End Sampling Start -22, 4, 242, 16846, 13, 281 16830, 51, 230 16882, 39, 242 16850, 11, 258 16803, -14, 220 16843, -24, 232 16855, 0, 241
Sanity checks:
2025-09-08 6:06 AM
Hello @Manoj_Bidari
Did you try with the BSP LSM6DSL Component driver?
2025-09-08 6:06 AM
Hello @Manoj_Bidari
2025-09-08 7:09 AM
Hello Saket,
Yes, i am using the BSP_LSM6DSL Component driver, even though i am facing the problems.
We would appreciate your guidance on resolving these issues.
2025-12-14 6:50 AM
Hello, any update regarding this issue? i am having similar problems.
