LSM330TR GYRO power_down mode
Riku Ueda
Posted on June 21, 2018 at 06:58
Hi, I'm in trouble about LSM330TR gyroscope power_down mode.
I'm measuring the angular velocity every 100ms and when it isn't measuring, i'd like to implement power_down mode.
I wrote such a program but t
he gyro data is just a random variant number.
When I use only normal mode, it works correctly.
How long does it take to start up from power_down mode to normal mode in gyroscope sampling sequence?
Please help me.
https://community.st.com/tags♯/?tags=inemo-inertial%20modules
https://community.st.com/tags♯/?tags=gyroscope
https://community.st.com/tags♯/?tags=lsm330tr
#lsm330tr #gyroscope #inemo-inertial-modules
Miroslav BATEK
Posted on June 21, 2018 at 11:06
The turn-on time from power down to normal mode is 150ms so you can you this approach if you want to measure the value each 100ms.
Posted on June 22, 2018 at 03:25
Thank you Miroslav, I made sure it works correctly!
I was looking for the information about power-down mode in this datasheet, but I couldn't.
https://www.mouser.jp/datasheet/2/389/lsm330-955021.pdf
I wonder if you tell me where can I see the description.
Posted on June 22, 2018 at 11:47
The LSM330 is obsolete sensor. Is no more present on st.com, you want be able to to find more information there.
I got the information about the turn-on time from sensor specialists.
