2015-12-28 2:18 PM
Is it possible to get some clarification on the performance distributions documented in the datasheet? If we were to calibrate a zero point and a (gain) two point cal for temperature drift per axis, are those parameters stable once a specific part has been manufactured, or can a single part drift over time the full range of the performance distributions?
#lis344alh
