LIS2DTW12 linux driver
‎2025-05-27 3:47 AM - last edited on ‎2025-05-27 3:52 AM by Peter BENSCH
Hi ST experts,
Is there any linux driver library available for LIS2DTW12?
Where can I find the related information/document?
Thanks.
Accelerometers
‎2025-05-29 12:23 AM
Hi @STLearner ,
You can look at the LIS2DW12 driver library that is very similar to LIS2DWT12 except for the temperature sensor.
Hope this helps :)
‎2025-05-27 3:57 AM
There is a standard C driver on Github, which can also be used for Linux: STMems_Standard_C_drivers/lis2dtw12_STdC.
Hope that helps?
/Peter
Hi @STLearner ,
Hope this helps :)
