2018-12-17 03:19 AM
I saw the VL53L1X used as a people counter video at:
https://www.youtube.com/watch?v=c91Ve-g0J2U
Is the source code used in that video available?
TIA,
2020-12-22 10:47 AM
Hi @Fdomi.1 , hope you are well.
I reached this page with my search on making something similar, I see that you wrotr at first that you had an issue with line 84 in this guy code, I'm in the same position. can you please share if you don't mide what made it work for you in the end. from the little I understood, "Dev->I2cDevAddr = 0x52;" is the part in the code where I'm trying to comunicate with the sensor, right? from some reason this line isn't returning any value...
will appriceae any help.....
