is there any sensing system that can measure the change in position with 0.01mm accuracy
Aanil.1
i want to have my CNC system moments feedback, which involves displacements of 0.01mm sensitivity
magene
Senior II
There are lots of sensors that can measure position with that level of resolution and accuracy. If you google position sensors for CNC machines you'll find a bunch. Also try googling linear position sensor, magnetic linear position sensor, LVDT or glass scale position sensor. Here's some examples: https://www.heidenhain.com/en_US/products/linear-encoders/
https://www.renishaw.com/en/resolute-absolute-encoder-system-with-rkla30-linear-and-partial-arc-scale--45094
https://www.mtssensors.com/Products/Industrial-Position-Sensors
6 REPLIES 6
John E KVAM
I don't think a sensor of this type whould work. Light is kind of fast. In units I deal with, it's 6.7 pico seconds per mm (round trip). To get that kind of resolution directly you would need a 300GHz scope and those are really expensive. To get sub mm, you would need one 10 times that fast.
To get that resolution in a sensor cheap enough for a CNC machine is out of the question.
Perhaps a very sensitive phisical swtich is the way go?
Good luck.
  • john
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
Aanil.1
Yeah! I absolutely agree with you Mr John. it would be tough with the TOF sensing tech for this accuracy..
But my view is in with modules that are used in digital Vernier callipers that gives 0.01mm accuracy.. and that would perfectly fits my application.. looking for something kind of these or similar ones
Thank you.
John E KVAM
I have one of those - and they are so cheap Harbor Freight gives them away as a 'free gift' if you buy something else.
But I don't know how they work.
But through the magic of Google, I got to:
Calipers
And the guy describes how they work.
Now all you have to do is find someone woul can build it for you.
The really interesting thing is that it works sort of like Indirect ToF. He even labels the vernears "sin" and "cos" indicating that they are determining phase shift.
Aanil.1
thanks a lot!
magene
Senior II
thanks for your valuable information!
