2021-03-30 09:04 AM
Hey,
I want to read acc+gyro from lsm6dso, and i'm using the read_data_pooling from examples. i'm using a 100hz timer to get the data from the sensor. Now i want a 10hz timer retreive the pedometer step counter. is it possible? how to configure both functionalities?
Thank you.
2021-03-30 09:35 AM
Enable the pedometer mode, and read the ****_SC_DELTAT_x registers at 1/10 th rate, ie after every 10 iterations of the acc+gyro reads.
