2018-07-31 12:27 AM
hai , iam using ii2328dq for reading the accelerometer values so here from sensor i got continues data how to know that frequency of data and could you pkease tell me how tocontrol that sensor data frequency.
2018-08-09 08:22 PM
https://www.st.com/resource/en/datasheet/iis328dq.pdf
Data sheet indicates ODR is controlled by PM and DR bits (CTRL_REG1) at rates up to 1 KHz. Decode the values therein.
