I have used LSM6DSO sensor to calculate the angle of inclination with the help of accelerometer. why the angle starts decreasing when it is rotated by 90 along y-axis and if i start rotating along x-axis ?
Vkj.1
niccolò
Hi @Vkj.1​ ,
it really depends on the algorithm you used to calculate it
did you use only the z axis value to calculate inclination?
if you only want the general inclination, not directed along an axis, you should do it
Niccolò
